跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Canon PowerShot SX120 IS Back Cover Replacement
你所需要的
  1. Canon PowerShot SX120 IS Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the double AA batteries before starting to disassemble. This will prevent you from permanently damaging your camera.
    • Turn the camera to the side that has the screen.
    • Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
  2. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 2 中的图像 1,1
    • Put the camera with the lens facing up, turn it to the side where the DC IN A/V OUT DIGITAL Cover and lanyard attachment are located.
    • Unscrew the black 3.4 mm screws with a #00 Phillips screwdriver.
  3. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 3 中的图像 1,3 Canon PowerShot SX120 IS Back Cover Replacement: 步骤 3 中的图像 2,3 Canon PowerShot SX120 IS Back Cover Replacement: 步骤 3 中的图像 3,3
    • Put the camera with the lens facing up, turn it to the side where the Cover battery is located.
  4. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 4 中的图像 1,2 Canon PowerShot SX120 IS Back Cover Replacement: 步骤 4 中的图像 2,2
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 5 中的图像 1,1
    • Put the camera with the lens facing down, turn it to the side where the DC IN A/V OUT DIGITAL Cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 6 中的图像 1,3 Canon PowerShot SX120 IS Back Cover Replacement: 步骤 6 中的图像 2,3 Canon PowerShot SX120 IS Back Cover Replacement: 步骤 6 中的图像 3,3
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully make pressure downwards on the opening tool so the cover can gradually open.
    • Keep making pressure and slowly slide the opening tool through all the gap.
    • There is one point when the cover will disassemble completely.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 7 中的图像 1,1
    • This is a final picture of how it's going to look when you disassemble the back cover.
    • You will have 3 parts:
    • 1. The camera
    • 2. The DC IN A/V OUT DIGITAL Cover
    • 3. The back cover.
结论
2等其他人完成本指南。
Maria
于03/13/14注册
875 声望
撰写一个指南
团队
一条评论
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
Frederick Czarnik - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,697
