跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot SX120 IS Back Cover Replacement
你所需要的
  1. Canon PowerShot SX120 IS Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
  2. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 2 中的图像 1,1
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
  3. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SX120 IS Back Cover Replacement: 步骤 3 中的图像 2,2
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
  4. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 4 中的图像 1,2 Canon PowerShot SX120 IS Back Cover Replacement: 步骤 4 中的图像 2,2
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 5 中的图像 1,1
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 6 中的图像 1,3 Canon PowerShot SX120 IS Back Cover Replacement: 步骤 6 中的图像 2,3 Canon PowerShot SX120 IS Back Cover Replacement: 步骤 6 中的图像 3,3
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Back Cover Replacement: 步骤 7 中的图像 1,1
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
结论
2等其他人完成本指南。
Maria
于03/13/14注册
935 声望
撰写一个指南
团队
1指南评论
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
Frederick Czarnik - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 62
总计 2,405
