跳转到主内容
Canon PowerShot SD870 IS LCD Replacement
你所需要的
  1. Canon PowerShot SD870 IS LCD Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Remove the wrist strap, if present.
    • Remove the lithium-ion battery.
  2. Canon PowerShot SD870 IS LCD Replacement: 步骤 2 中的图像 1,3 Canon PowerShot SD870 IS LCD Replacement: 步骤 2 中的图像 2,3 Canon PowerShot SD870 IS LCD Replacement: 步骤 2 中的图像 3,3
    • Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
    • Remove the screw next to the wrist strap attachment.
    • Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
  3. Canon PowerShot SD870 IS LCD Replacement: 步骤 3 中的图像 1,1
    • Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
  4. Canon PowerShot SD870 IS LCD Replacement: 步骤 4 中的图像 1,2 Canon PowerShot SD870 IS LCD Replacement: 步骤 4 中的图像 2,2
    • Pull the front cover from the camera by using gentle upward pressure.
  5. Canon PowerShot SD870 IS LCD Replacement: 步骤 5 中的图像 1,2 Canon PowerShot SD870 IS LCD Replacement: 步骤 5 中的图像 2,2
    • Remove the two Phillips #00 screws from the flat end of the camera.
    • Remove the black L-shaped side cover plate.
    • Remove the silver u-shaped retainer plate.
  6. Canon PowerShot SD870 IS LCD Replacement: 步骤 6 中的图像 1,1
    • Slide the back casing off.
  7. Canon PowerShot SD870 IS LCD Replacement, LCD: 步骤 7 中的图像 1,1
    • The first screw that needs to be removed is located on the bottom of the camera, on the left hand side.
    • Using a Phillips #00 screwdriver remove the 0.133in silver screw on the bottom left-hand side.
  8. Canon PowerShot SD870 IS LCD Replacement: 步骤 8 中的图像 1,2 Canon PowerShot SD870 IS LCD Replacement: 步骤 8 中的图像 2,2
    • The second screw that needs to be removed is located on the top of the camera.
    • Using the same Phillips head screwdriver, remove the last 0.133in silver screw.
    • This will detach a silver U-shaped piece that was holding LCD screen on. Remove the piece and put it to the side.
  9. Canon PowerShot SD870 IS LCD Replacement: 步骤 9 中的图像 1,1
    • The LCD screen should now only be attached by the LCD data cable.
    • Lift the screen from the right side and use a small screwdriver or other small opening device to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
    • The LCD should still be connected by the backlight cable.
  10. Canon PowerShot SD870 IS LCD Replacement: 步骤 10 中的图像 1,2 Canon PowerShot SD870 IS LCD Replacement: 步骤 10 中的图像 2,2
    • To remove the backlight cable, use another small opening device to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen should now be fully detached from the camera body.
  11. Canon PowerShot SD870 IS LCD Replacement: 步骤 11 中的图像 1,1
    • The LCD screen casing is connected by 4 claws located on the top and bottom on the left and right hand side.
    • Carefully disengage the claws by gently prying them off one by one.
    • Once the claws are disengaged, the back of the casing will still be connected to the front casing by the backlight cable.
    • Carefully peel the backlight cable off of the casing.
  12. Canon PowerShot SD870 IS LCD Replacement: 步骤 12 中的图像 1,1
    • The LCD screen and housing should now be in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD screen back housing
    • The LCD screen itself can now be removed and fixed/replaced.
结论
5等其他人完成本指南。
Sam
于04/15/10注册
155 声望
创作了5篇指南
团队
Cal Poly, Team 10-45, Garner Spring 2010 Cal Poly, Team 10-45, Garner Spring 2010 的会员
CPSU-GARNER-S10S10G45
4 名成员
创作了6篇指南
2指南评论
if not taking the battery out before beginning this repair damaged the camera... thanks for not making mention of that...
Dan - 回复
my 870sd has a grey dot on the screen. does the whole screen need to be replaced. also the lens comes out but does not focus at all. what could that be. thank you jim
Jim Hald - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 49
总计 18,520
