本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to remove a broken Motherboard from your Canon PowerShot SD850 IS.
你所需要的
Slide the light grey tab toward the edge of the camera using your fingernail.
Pull the light grey tab up to open the door.
Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
Remove four screws located on the back of the camera:
6.15 mm #00 Phillips
2.75 mm #00 Phillips
2.15 mm #00 Phillips
2.7 mm #00 Phillips
