当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Slide the light grey tab toward the edge of the camera using your fingernail.
Pull the light grey tab up to open the door.
These photos do not show the camera’s memory card or battery, which should be visible inside.
Slide the small brown tab toward the edge of the camera using your fingernail.
Let go of the brown tab when the battery pops up.
Grab battery and pull straight up to remove from holder.
When inserting the battery, orient it so that the terminals connect.
Remove the following 4 screws:
Two 2.8 mm Phillips #00 at the bottom of the camera.
Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
Slide light gray door and pull up to open the door.
Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
The LCD screen should now only be attached by two LCD data cables.
Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
Carefully slide the data cable out of the connector.
The LCD should still be connected by the backlight cable.
To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
Carefully slide out the backlight cable.
The LCD screen can now be fully detached from the camera body.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
