跳转到主内容
Canon PowerShot SD850 IS Housing Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Canon PowerShot SD850 IS Housing Replacement, Housing: 步骤 1 中的图像 1,3 Canon PowerShot SD850 IS Housing Replacement, Housing: 步骤 1 中的图像 2,3 Canon PowerShot SD850 IS Housing Replacement, Housing: 步骤 1 中的图像 3,3
    • To avoid severe electric shock do not remove or tamper with internal camera flash components. An electrical capacitor is attached to the flash that can discharge if contact is made.
    • Remove the two side screws, indicated by the red circles, using a Phillips #00 screwdriver.
    • Remove the screw in the battery port, indicated by the blue circle, again using a Phillips #00 screwdriver.
    • Remove the front face by gently peeling the housing away from the camera.
  2. Canon PowerShot SD850 IS Housing Replacement: 步骤 2 中的图像 1,3 Canon PowerShot SD850 IS Housing Replacement: 步骤 2 中的图像 2,3 Canon PowerShot SD850 IS Housing Replacement: 步骤 2 中的图像 3,3
    • Remove the back face by using a spudger to lift the tab highlighted in yellow
    • Pivot the back face clockwise as seen in the second photo.
  3. Canon PowerShot SD850 IS Housing Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SD850 IS Housing Replacement: 步骤 3 中的图像 2,2
    • Remove the A/V port cover [no tools are necessary]
结论
iDeleted
于07/07/10注册
2,101 声望
创作了39篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 854
