跳转到主内容
Canon PowerShot SD850 IS Function Set Button Replacement
你所需要的
  1. Canon PowerShot SD850 IS Function Set Button Replacement, Battery: 步骤 1 中的图像 1,3 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: 步骤 1 中的图像 2,3 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: 步骤 1 中的图像 3,3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 2 中的图像 2,2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Canon PowerShot SD850 IS Function Set Button Replacement, Case: 步骤 3 中的图像 1,2 Canon PowerShot SD850 IS Function Set Button Replacement, Case: 步骤 3 中的图像 2,2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 4 中的图像 1,3 Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 4 中的图像 2,3 Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 4 中的图像 3,3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 5 中的图像 1,2 Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 5 中的图像 2,2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 6 中的图像 1,2 Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 6 中的图像 2,2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 7 中的图像 1,1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 8 中的图像 1,1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: 步骤 9 中的图像 1,2 Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: 步骤 9 中的图像 2,2
    • Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
  10. Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 10 中的图像 1,1
    • Lift the function set button ribbon cable from the two guide pins.
  11. Canon PowerShot SD850 IS Function Set Button Replacement: 步骤 11 中的图像 1,1
    • Remove the ribbon cable by lifting on the flat tab and pulling the ribbon cable from the connection.
结论
iDeleted
于07/07/10注册
2,101 声望
创作了39篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 1,287
