本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to remove a broken flash unit from your Canon PowerShot SD850 IS.
你所需要的
Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
即将完成!
结论
