跳转到主内容
Canon PowerShot SD850 IS Camera Lens Replacement
你所需要的
  1. Canon PowerShot SD850 IS Camera Lens Replacement, Case: 步骤 1 中的图像 1,2 Canon PowerShot SD850 IS Camera Lens Replacement, Case: 步骤 1 中的图像 2,2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  2. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 2 中的图像 1,3 Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 2 中的图像 2,3 Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 2 中的图像 3,3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  3. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 3 中的图像 2,2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  4. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 4 中的图像 1,2 Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 4 中的图像 2,2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  5. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 5 中的图像 1,1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  6. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 6 中的图像 1,1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  7. Canon PowerShot SD850 IS Camera Lens Replacement, LCD Screen: 步骤 7 中的图像 1,1
    • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
  8. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 8 中的图像 1,1
    • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
  9. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 9 中的图像 1,2 Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 9 中的图像 2,2
    • Remove the two metal frames that hold the LCD panel in place.
  10. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 10 中的图像 1,1
    • The LCD screen should now only be attached by two LCD data cables.
    • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
    When reassembling the camera, the tab that gets flipped up to release the cable will not lock back down into place after the cable is reinserted.
    Schu - 回复
  11. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 11 中的图像 1,1
    • The LCD should still be connected by the backlight cable.
    • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen can now be fully detached from the camera body.
    How to unlock the backlight cable is not at all clear. This also leads to a problem with how to reinsert and lock the cable while putting the camera back together.
    Schu - 回复
  12. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 12 中的图像 1,2 Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 12 中的图像 2,2
    • The LCD screen and housing are now in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD back housing
    • The LCD screen itself can now be removed and fixed/replaced.
  13. Canon PowerShot SD850 IS Camera Lens Replacement, Flash Unit: 步骤 13 中的图像 1,1
    • Remove the 1.85 mm #00 Phillips located on the left side of the camera.
  14. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 14 中的图像 1,2 Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 14 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a set of tweezers to remove the speaker located at the top of the camera on the flash unit.
    • Next use the tweezers to carefully remove the speaker cable off its respective holders.
  15. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 15 中的图像 1,1
    • Use a spudger or a flathead screwdriver to remove the camera lens cable located in the front of the camera.
  16. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 16 中的图像 1,2 Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 16 中的图像 2,2
    • Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
    • Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
  17. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 17 中的图像 1,1
    • Gently remove the flash component from the rest of the camera.
    • Use a spudger or a flathead screwdriver and carefully pry off the plastic piece on top of the flash unit.
    • The flash unit can now be removed and replaced.
    • Be careful not to touch the capacitor attached to the flash unit as it may still be holding a charge!
  18. Canon PowerShot SD850 IS Camera Lens Replacement, Camera Lens: 步骤 18 中的图像 1,1
    • Remove four screws located on the back of the camera:
    • 6.15 mm #00 Phillips
    • 2.75 mm #00 Phillips
    • 2.15 mm #00 Phillips
    • 2.7 mm #00 Phillips
  19. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 19 中的图像 1,1
    • Use a spudger or a flathead screwdriver and carefully pry out the bulb located in the front of the camera on top of the camera lens.
  20. Canon PowerShot SD850 IS Camera Lens Replacement: 步骤 20 中的图像 1,1
    • Gently remove the camera lens from the rest of the camera.
结论
3等其他人完成本指南。
Peter Tran
于10/06/10注册
225 声望
创作了6篇指南
团队
Cal Poly, Team 20-7, Maness Fall 2010 Cal Poly, Team 20-7, Maness Fall 2010 的会员
CPSU-MANESS-F10S20G7
6 名成员
创作了7篇指南
一条评论
If you have a problem on your camera then it is better if you go nearest technician to fix your camera.
Get a good action camera at http://actionshotcam.com
Jerome Tenedero - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 14,136
