当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Slide the light grey tab toward the edge of the camera using your fingernail.
Pull the light grey tab up to open the door.
These photos do not show the camera’s memory card or battery, which should be visible inside.
Slide the small brown tab toward the edge of the camera using your fingernail.
Let go of the brown tab when the battery pops up.
Grab battery and pull straight up to remove from holder.
When inserting the battery, orient it so that the terminals connect.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
