跳转到主内容
Canon PowerShot SD780 IS USB Port Replacement
你所需要的
  1. Canon PowerShot SD780 IS USB Port Replacement, USB Port: 步骤 1 中的图像 1,1
    • Begin by turning off the camera and removing the battery to avoid any shock injuries.
  2. Canon PowerShot SD780 IS USB Port Replacement: 步骤 2 中的图像 1,1
    • After the battery is removed, use a screwdriver to remove the five outermost screws on the camera to allow for a case replacement. Keep in mind that keeping track of where each screw came from is crucial for when putting the camera back together.
  3. Canon PowerShot SD780 IS USB Port Replacement: 步骤 3 中的图像 1,1
    • There are 2 screws located on the left side of the camera. These screw locations are depicted with the red circle markings in the photos. These screws are 2.0 mm long.
  4. Canon PowerShot SD780 IS USB Port Replacement: 步骤 4 中的图像 1,1
    • Remove the front panel of the camera case to expose the top left copper strip. Gently pull upward on the strip to disconnect it from the camera.
  5. Canon PowerShot SD780 IS USB Port Replacement: 步骤 5 中的图像 1,1
    • Once you remove the back portion of the camera, you will see the charging component. Remove the metallic strip on the charging component which attaches it to the motherboard.
  6. Canon PowerShot SD780 IS USB Port Replacement: 步骤 6 中的图像 1,1
    • Using a screwdriver, remove the screw that attaches the charging mechanism to the body of the camera. This will allow the mechanism to be released from the camera.
结论
另外一个人完成了本指南。
Arlene Ale
于03/13/14注册
455 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 450
