跳转到主内容
Canon PowerShot SD700 Motherboard Replacement
你所需要的
  1. Canon PowerShot SD700 Motherboard Replacement, Outside Case: 步骤 1 中的图像 1,1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Once the LCD and Backlight are detached, remove the larger screw marked in red in the picture as well as the four smaller sized screws marked in blue.
  8. Canon PowerShot SD700 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the two screws near the the tri-pod mount with a Philips head screw driver.
  9. Canon PowerShot SD700 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the screw next to the shutter with a Philip's head screw driver.
  10. Canon PowerShot SD700 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the orange ribbon cable by lifting the ZIF connector attached to the ribbon with a flat head screw driver or spudger.
  11. Canon PowerShot SD700 Motherboard Replacement: 步骤 11 中的图像 1,2 Canon PowerShot SD700 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Carefully lift the shutter along with the ribbon connected to it. This will remove the casing around the motherboard.
  12. Canon PowerShot SD700 Motherboard Replacement: 步骤 12 中的图像 1,3 Canon PowerShot SD700 Motherboard Replacement: 步骤 12 中的图像 2,3 Canon PowerShot SD700 Motherboard Replacement: 步骤 12 中的图像 3,3
    • With the motherboard casing detached, remove the short orange ribbon by lifting the ZIF connector with a spudger or other plastic opening tools and slide the ribbon out. Detaching this ribbon will disconnect the side of the camera containing the motherboard from the rest of the camera.
  13. Canon PowerShot SD700 Motherboard Replacement: 步骤 13 中的图像 1,2 Canon PowerShot SD700 Motherboard Replacement: 步骤 13 中的图像 2,2
    • First remove the wires that are attached to the motherboard, as shown by the black box. You can detach them by simply pulling them out.
    • Next you can remove the film by lifting it gently from the motherboard.
  14. Canon PowerShot SD700 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the last wires connected to the motherboard. You can remove it by gently lifting it upwards.
  15. Canon PowerShot SD700 Motherboard Replacement: 步骤 15 中的图像 1,2 Canon PowerShot SD700 Motherboard Replacement: 步骤 15 中的图像 2,2
    • Place a flathead screwdriver and gently lift the circuit attached, as shown on the picture.
  16. Canon PowerShot SD700 Motherboard Replacement: 步骤 16 中的图像 1,2 Canon PowerShot SD700 Motherboard Replacement: 步骤 16 中的图像 2,2
    • Remove the screw using a philip 00 screwdriver.
    • Once the screw is removed, gently lift the motherboard away from the case.
  17. Canon PowerShot SD700 Motherboard Replacement: 步骤 17 中的图像 1,2 Canon PowerShot SD700 Motherboard Replacement: 步骤 17 中的图像 2,2
    • Remove the screw as shown by the red circle.
    • Once the screw is removed, you can remove the board.
结论
Kenneth Lim
于04/07/11注册
61 声望
创作了2篇指南
团队
Cal Poly, Team 9-71, Walters Spring 2011 Cal Poly, Team 9-71, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G71
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,319
