跳转到主内容
Canon PowerShot SD700 LCD screen Replacement
你所需要的
  1. Canon PowerShot SD700 LCD screen Replacement, Outside Case: 步骤 1 中的图像 1,1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 LCD screen Replacement: 步骤 2 中的图像 1,1
    • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
  3. Canon PowerShot SD700 LCD screen Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
  4. Canon PowerShot SD700 LCD screen Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
  5. Canon PowerShot SD700 LCD screen Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 LCD screen Replacement: 步骤 6 中的图像 1,1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 LCD screen Replacement, LCD screen: 步骤 7 中的图像 1,1
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Canon PowerShot SD700 LCD screen Replacement: 步骤 8 中的图像 1,3 Canon PowerShot SD700 LCD screen Replacement: 步骤 8 中的图像 2,3 Canon PowerShot SD700 LCD screen Replacement: 步骤 8 中的图像 3,3
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Canon PowerShot SD700 LCD screen Replacement: 步骤 9 中的图像 1,1
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
结论
2等其他人完成本指南。
Emilio Rossi
于04/07/11注册
113 声望
创作了3篇指南
团队
Cal Poly, Team 9-71, Walters Spring 2011 Cal Poly, Team 9-71, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G71
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 16
总计 2,847
