跳转到主内容
Canon PowerShot SD700 E18 Error Replacement
你所需要的
  1. Canon PowerShot SD700 E18 Error Replacement, Outside Case: 步骤 1 中的图像 1,1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 E18 Error Replacement: 步骤 2 中的图像 1,1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 E18 Error Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 E18 Error Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 E18 Error Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 E18 Error Replacement: 步骤 6 中的图像 1,1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. 在这个步骤中使用的工具:
    Dust Blower
    购买
    • Clean the lens and the area surrounding the lens with a soft brush and dust blower.
    • Tweezers can be helpful when removing sand.
    • Reassemble the camera and if the E18 error persists, further disassembly of the camera may be required.
结论
To reassemble your device, follow steps 1-6 instructions in reverse order.
另外一个人完成了本指南。
Aaron Lee
于04/07/11注册
212 声望
创作了3篇指南
团队
Cal Poly, Team 9-71, Walters Spring 2011 Cal Poly, Team 9-71, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G71
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 2,912
