跳转到主内容
Canon PowerShot SD500 Digital ELPH LCD Replacement
你所需要的
  1. Canon PowerShot SD500 Digital ELPH LCD Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 2 中的图像 2,2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH LCD Replacement, Front and Rear Casing: 步骤 3 中的图像 1,2 Canon PowerShot SD500 Digital ELPH LCD Replacement, Front and Rear Casing: 步骤 3 中的图像 2,2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 4 中的图像 1,1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 5 中的图像 1,1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 6 中的图像 1,1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 7 中的图像 1,1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 8 中的图像 1,1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 9 中的图像 1,2 Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 9 中的图像 2,2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH LCD Replacement, Button Contact Panel: 步骤 10 中的图像 1,1
    • Carefully wedge the pry tool under the ribbon in the ribbon gate.
    • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
    • Be careful not to damage the ribbon.
  11. Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 11 中的图像 1,1
    • Gently press the ribbon back to get access to a Phillips screw behind it.
    • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
  12. Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 12 中的图像 1,3 Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 12 中的图像 2,3 Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 12 中的图像 3,3
    • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
    • Pull the button board away from the rest of the camera.
  13. Canon PowerShot SD500 Digital ELPH LCD Replacement, LCD: 步骤 13 中的图像 1,1
    • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
  14. Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 14 中的图像 1,1
    • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
    • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
  15. Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 15 中的图像 1,2 Canon PowerShot SD500 Digital ELPH LCD Replacement: 步骤 15 中的图像 2,2
    • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
    • The LCD can now be completely removed from the camera.
结论
3等其他人完成本指南。
Taylor Shields
于10/13/14注册
846 声望
创作了8篇指南
团队
Clemson, Team 2-1, Benson Fall 2014 Clemson, Team 2-1, Benson Fall 2014 的会员
CLEM-BENSON-F14S2G1
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 22
总计 916
