跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Canon PowerShot SD450 Outer Case replacement
你所需要的
  1. Canon PowerShot SD450 Outer Case replacement, Casing: 步骤 1 中的图像 1,1
    • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
    • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
  2. Canon PowerShot SD450 Outer Case replacement: 步骤 2 中的图像 1,1
    • Pull the lanyard mount off of the camera using a spudger or your fingers.
  3. Canon PowerShot SD450 Outer Case replacement: 步骤 3 中的图像 1,2 Canon PowerShot SD450 Outer Case replacement: 步骤 3 中的图像 2,2
    • Find the line that separates the casing into its two halves. Hold each half seperately, and gently pull apart.
    • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  4. Canon PowerShot SD450 Outer Case replacement: 步骤 4 中的图像 1,1
    • Take hold of the inside of the camera, and gently pull away from the back casing.
  5. Canon PowerShot SD450 Outer Case replacement: 步骤 5 中的图像 1,1
    • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
  6. Canon PowerShot SD450 Outer Case replacement: 步骤 6 中的图像 1,1
    • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
    • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
结论
另外一个人完成了本指南。
Curtis Wagner
于04/10/10注册
32 声望
撰写一个指南
团队
Cal Poly, Team 25-85, Amido Spring 2010 Cal Poly, Team 25-85, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G85
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 3,532
