跳转到主内容
Canon PowerShot SD400 LCD Replacement
你所需要的
  1. Canon PowerShot SD400 LCD Replacement, Battery: 步骤 1 中的图像 1,2 Canon PowerShot SD400 LCD Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the battery cover open (indicated by the red box).
  2. Canon PowerShot SD400 LCD Replacement: 步骤 2 中的图像 1,1
    • Push in the orange clip (indicated by the red box) to eject the battery.
  3. Canon PowerShot SD400 LCD Replacement: 步骤 3 中的图像 1,1
    • Insert the charged battery back into the slot (indicated by the red box).
    • Close the cover.
  4. Canon PowerShot SD400 LCD Replacement, LCD: 步骤 4 中的图像 1,3 Canon PowerShot SD400 LCD Replacement, LCD: 步骤 4 中的图像 2,3 Canon PowerShot SD400 LCD Replacement, LCD: 步骤 4 中的图像 3,3
    • Locate these six screws that need to be removed to open the camera’s housing. These screws can be found on the bottom and both sides of the camera.
  5. Canon PowerShot SD400 LCD Replacement: 步骤 5 中的图像 1,3 Canon PowerShot SD400 LCD Replacement: 步骤 5 中的图像 2,3 Canon PowerShot SD400 LCD Replacement: 步骤 5 中的图像 3,3
    • Using the screwdriver, carefully remove the exterior screws and place them in a safe location to avoid misplacing them.
  6. Canon PowerShot SD400 LCD Replacement: 步骤 6 中的图像 1,2 Canon PowerShot SD400 LCD Replacement: 步骤 6 中的图像 2,2
    • Locate the interior screw that is above the top right of the LCD screen.
    • Remove the screw using the screwdriver.
  7. Canon PowerShot SD400 LCD Replacement: 步骤 7 中的图像 1,3 Canon PowerShot SD400 LCD Replacement: 步骤 7 中的图像 2,3 Canon PowerShot SD400 LCD Replacement: 步骤 7 中的图像 3,3
    • Locate the two clips on the left side of the LCD screen.
    • Carefully insert the tip of a flat-head screwdriver under the two clips of the LCD screen.
    • Slowly lift the screen using the flat-head screwdriver.
    • Potential for device damage Lift the screen gently to avoid any damage.
结论
2等其他人完成本指南。
Yi Huang Ke
于10/18/11注册
51 声望
创作了4篇指南
团队
James Madison, Team 1-1, Allen Fall 2011 James Madison, Team 1-1, Allen Fall 2011 的会员
JMU-ALLEN-F11S1G1
4 名成员
创作了4篇指南
1指南评论
Do you carry a lcd screen for the Powershot sd400?
Jesus Licon - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 3,625
