跳转到主内容
Canon PowerShot SD30 Screen Replacement
你所需要的
  1. Canon PowerShot SD30 Screen Replacement, Front Cover: 步骤 1 中的图像 1,2 Canon PowerShot SD30 Screen Replacement, Front Cover: 步骤 1 中的图像 2,2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Screen Replacement: 步骤 2 中的图像 1,1
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Screen Replacement, Back Cover: 步骤 3 中的图像 1,3 Canon PowerShot SD30 Screen Replacement, Back Cover: 步骤 3 中的图像 2,3 Canon PowerShot SD30 Screen Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Screen Replacement: 步骤 4 中的图像 1,1
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Screen Replacement, Screen: 步骤 5 中的图像 1,2 Canon PowerShot SD30 Screen Replacement, Screen: 步骤 5 中的图像 2,2
    • Remove top button panel by removing the screw located at the top right of the panel.
  6. Canon PowerShot SD30 Screen Replacement: 步骤 6 中的图像 1,2 Canon PowerShot SD30 Screen Replacement: 步骤 6 中的图像 2,2
    • Remove screws both at the top and the base of the screen to free the screen.
  7. Canon PowerShot SD30 Screen Replacement: 步骤 7 中的图像 1,3 Canon PowerShot SD30 Screen Replacement: 步骤 7 中的图像 2,3 Canon PowerShot SD30 Screen Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to lift the tab that secures the screen wire and remove.
    • You need to do this for both wires.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 264
