跳转到主内容
Canon PowerShot SD30 Motherboard Replacement
你所需要的
  1. Canon PowerShot SD30 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Canon PowerShot SD30 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Canon PowerShot SD30 Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  2. Canon PowerShot SD30 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Gently remove the back cover.
  3. Canon PowerShot SD30 Motherboard Replacement, Front Cover: 步骤 3 中的图像 1,2 Canon PowerShot SD30 Motherboard Replacement, Front Cover: 步骤 3 中的图像 2,2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  4. Canon PowerShot SD30 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Gently remove the front cover.
  5. Canon PowerShot SD30 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 Canon PowerShot SD30 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Unscrew the 3mm silver screw from the top of the camera.
    • Gently remove the top button panel.
  6. Canon PowerShot SD30 Motherboard Replacement: 步骤 6 中的图像 1,2 Canon PowerShot SD30 Motherboard Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the tweezers, carefully lift up the 2 folds where the ribbon connects to the motherboard.
    • Now, lift up the three remaining ribbon connectors to disconnect them.
  7. Canon PowerShot SD30 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Unscrew the three 3mm silver screws from the motherboard.
  8. Canon PowerShot SD30 Motherboard Replacement: 步骤 8 中的图像 1,3 Canon PowerShot SD30 Motherboard Replacement: 步骤 8 中的图像 2,3 Canon PowerShot SD30 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Gently pull the left wire out and disconnect it from the device.
    • Use the tweezers to pop the right set of wires out of the connector. Do this by positioning the tweezers under the connector and lifting up.
  9. Canon PowerShot SD30 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the motherboard from the device.
    • The motherboard will have nothing connecting it to anything, so be sure to have it grasped.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 177
