当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use your fingernail to slide the dark gray tab towards the edge of the camera.
Slide the light gray door away from the LCD screen and pull up to open the door.
The battery and the memory card slots should now be visible.
Press down on the memory card.
Memory card should pop out of place.
Pull the memory card straight out of the slot.
When putting the memory card back in, orient the memory card in the same direction when pulling out.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
