跳转到主内容
修复你的物品
维修的权力
商店
简介
The Canon PowerShot SD200 has an opening for a SD Memory Card. Removing the memory card might be necessary to obtain pictures from the camera. This guide will show how to easily remove the memory card.
  1. Use your fingernail to slide the dark gray tab towards the edge of  the camera. Slide the light gray door away from the LCD screen and pull up to open the door. The battery and the memory card slots should now be visible.
    • Use your fingernail to slide the dark gray tab towards the edge of the camera.
    • Slide the light gray door away from the LCD screen and pull up to open the door.
    • The battery and the memory card slots should now be visible.
  2. Press down on the memory card.
    • Press down on the memory card.
    • Memory card should pop out of place.
    • Pull the memory card straight out of the slot.
    • When putting the memory card back in, orient the memory card in the same direction when pulling out.
结论
另外一个人完成了本指南。
James Loy
于2010年10月06日注册
103 信誉积分
创作了7篇指南
团队
Cal Poly, Team 5-12, Maness Fall 2010 Cal Poly, Team 5-12, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G12
4 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,291
