跳转到主内容
Canon PowerShot SD200 Battery Replacement
  1. Canon PowerShot SD200 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Canon PowerShot SD200 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Canon PowerShot SD200 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • The camera used to create these repair guides had a broken lens assembly. As a result, the lens is sticking out in all of the photos, but it is important to note that this should not be the case with your camera. The lens should retract itself back into the camera when it is turned off.
    • Use your fingernail to slide the dark gray tab located on the bottom of the device towards the edge of camera.
    • Slide the light gray door away from the LCD screen and pull up to open the door.
    • Both battery and memory card should now be visible.
  2. Canon PowerShot SD200 Battery Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SD200 Battery Replacement: 步骤 2 中的图像 2,2
    • Rotate the small brown tab towards the edge of the camera.
    • The battery should pop up.
  3. Canon PowerShot SD200 Battery Replacement: 步骤 3 中的图像 1,1
    • Pull the battery straight out of the battery holder.
    • When putting the battery back in, make sure it is oriented the same as it was before.
结论
James Loy
于10/06/10注册
103 声望
创作了7篇指南
团队
Cal Poly, Team 5-12, Maness Fall 2010 Cal Poly, Team 5-12, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G12
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 3,001
