跳转到主内容
Canon PowerShot SD1400 IS User Interface Panel Replacement
你所需要的
  1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: 步骤 1 中的图像 1,3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: 步骤 1 中的图像 2,3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: 步骤 1 中的图像 3,3
    • Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
  2. Canon PowerShot SD1400 IS User Interface Panel Replacement: 步骤 2 中的图像 1,1
    • Remove the 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS User Interface Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the front face panel of the camera by hand using firm pressure.
    • If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
  4. Canon PowerShot SD1400 IS User Interface Panel Replacement: 步骤 4 中的图像 1,1
    • Remove the rear panel of the camera by hand using firm pressure.
  5. Canon PowerShot SD1400 IS User Interface Panel Replacement: 步骤 5 中的图像 1,1
    • Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
    • Replace the user interface panel by setting it in position.
结论
2等其他人完成本指南。
Braxton Beal
于01/30/18注册
702 声望
创作了3篇指南
团队
Baylor, Team S1-G3, Johnson Spring 2018 Baylor, Team S1-G3, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G3
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 432
