跳转到主内容
Canon PowerShot SD1400 IS Image Capture Button Replacement
你所需要的
  1. Canon PowerShot SD1400 IS Image Capture Button Replacement, Image Capture Button: 步骤 1 中的图像 1,2 Canon PowerShot SD1400 IS Image Capture Button Replacement, Image Capture Button: 步骤 1 中的图像 2,2
    • Use a Phillips #00 driver to remove the four 2.0 mm Phillips screws on the camera housing.
    • There are two screws on either side.
  2. Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 driver to remove the one 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 3 中的图像 1,1
    • Remove the face housing from the body of the camera.
  4. Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 4 中的图像 1,1
    • Turn the camera over and remove the rear housing.
  5. Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 5 中的图像 1,1
    • Remove the button panel if it did not fall out on its own.
  6. Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips copper screw from the top of the camera.
    • This screw is only visible after the front and rear panels have been removed.
  7. Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 7 中的图像 1,1
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips silver screw from the rear face of the camera.
  8. Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 8 中的图像 1,1
    • Use a plastic spudger to lift the golden film off of the microchip on the front face of the camera, exposing a screw.
  9. Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 9 中的图像 1,1
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips screw.
  10. Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 10 中的图像 1,2 Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 10 中的图像 2,2
    • Use a metal spudger to carefully pry the small black tab away from the connector that secures one end of the golden film.
    • When fully released, the small black tab will stand up straight from the face of the camera and the golden film will no longer be secured.
  11. Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 11 中的图像 1,1
    • Carefully insert a metal spudger under the two clusters of wires that are plugged into the small chip on the face of the camera.
    • One cluster of wires is red, the other cluster is black.
    • Pull the wires parallel to the face of the camera to disconnect them from the small chip.
  12. Canon PowerShot SD1400 IS Image Capture Button Replacement: 步骤 12 中的图像 1,1
    • The image capture button housing can now be removed from the body of the camera and replaced.
结论
Follow these instructions in reverse order to reassemble the device.
另外一个人完成了本指南。
Braxton Beal
于01/30/18注册
702 声望
创作了3篇指南
团队
Baylor, Team S1-G3, Johnson Spring 2018 Baylor, Team S1-G3, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G3
3 名成员
创作了4篇指南
1指南评论
Where can do you buy replacement parts?
Chase Mahard - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 455
