简介
This guide will show you how to properly replace a faulty lens on your Canon PowerShot SD1300 IS.
你所需要的
2等其他人完成本指南。
一条评论
I have a SD1300 IS and it has another case screw beneath a plastic cover just below the USB port.
Also step 4 shows 2 screws to remove on the lens that do not go through the metal frame. These should not be removed for lens removal.
It is necessary on mine to remove the 2 screws on the left side of the metal frame that attach to the lens assy.
