跳转到主内容
Canon PowerShot SD1200 IS LCD Replacement
你所需要的
  1. Canon PowerShot SD1200 IS LCD Replacement, Front and Rear Covers: 步骤 1 中的图像 1,1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS LCD Replacement: 步骤 2 中的图像 1,3 Canon PowerShot SD1200 IS LCD Replacement: 步骤 2 中的图像 2,3 Canon PowerShot SD1200 IS LCD Replacement: 步骤 2 中的图像 3,3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS LCD Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SD1200 IS LCD Replacement: 步骤 3 中的图像 2,2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS LCD Replacement, LCD: 步骤 4 中的图像 1,3 Canon PowerShot SD1200 IS LCD Replacement, LCD: 步骤 4 中的图像 2,3 Canon PowerShot SD1200 IS LCD Replacement, LCD: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Use the spudger to lift the retaining flap on the Zero Insertion Force (ZIF) tab securing the thick ribbon cable.
    • Slide out the ribbon cable using fingers or tweezers.
    • Be sure you are prying up on the hinged retaining flap, not the connector.
    • Using tweezers, disconnect the small ribbon cable below the flash assembly from the No Fuss Connector by simply pulling the ribbon cable straight out.
  5. Canon PowerShot SD1200 IS LCD Replacement: 步骤 5 中的图像 1,3 Canon PowerShot SD1200 IS LCD Replacement: 步骤 5 中的图像 2,3 Canon PowerShot SD1200 IS LCD Replacement: 步骤 5 中的图像 3,3
    • Remove the L shaped brackets from the left and right side of the LCD screen with the spudger tool.
    • The Brackets have tabs that need to be pried up.
    • Remove the screw below the shutter button. (2.5mm Phillips 00)
    • Holding the sides of the LCD screen, lift the screen up and away to remove.
结论
2等其他人完成本指南。
Jeff Casper
于09/15/16注册
897 声望
创作了7篇指南
团队
USF Tampa, Team 17-5, Blackwell Fall 2016 USF Tampa, Team 17-5, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S17G5
3 名成员
创作了7篇指南
1指南评论
Hello do you guys sello the LCD screen and do you ship to México.
Killer King - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 832
