当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
Remove the two screws from the bottom of the camera. (4mm Phillips 00)
Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
Pull off the front cover.
If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
Remove the back cover.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
