跳转到主内容
Canon PowerShot SD1200 IS Front and Rear Covers Replacement
你所需要的
  1. Canon PowerShot SD1200 IS Front and Rear Covers Replacement, Front and Rear Covers: 步骤 1 中的图像 1,1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Front and Rear Covers Replacement: 步骤 2 中的图像 1,3 Canon PowerShot SD1200 IS Front and Rear Covers Replacement: 步骤 2 中的图像 2,3 Canon PowerShot SD1200 IS Front and Rear Covers Replacement: 步骤 2 中的图像 3,3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Front and Rear Covers Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SD1200 IS Front and Rear Covers Replacement: 步骤 3 中的图像 2,2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
结论
2等其他人完成本指南。
Jeff Casper
于09/15/16注册
860 声望
创作了7篇指南
团队
USF Tampa, Team 17-5, Blackwell Fall 2016 USF Tampa, Team 17-5, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S17G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 19
总计 1,058
