该版本可能包含错误编辑。跳转到最新已认证的截图。
难度
中等
步骤
12
所需时间
20分钟
节
3
标志
0
Spudger
$3.99
没有特定配件。
这个步骤还没有翻译 帮忙翻译一下
Remove wrist strap and battery.
Remove 2 screws from each side of the camera (4 total, 0.102 in).
Remove 2 screws from the bottom on the camera (0.138 in).
Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
Gently pull off the front cover.
The plate on the side should come off.
Gently pull off the back cover.
The cases should now be removed.
Use the spudger to disconnect the black tab.
Gently pull off the shutter button assembly.
Use the tweezers to disconnect the microphone cable.
The shutter button assembly should now be removed.
With the spudger, flip up the black tab on the main ribbon.
Gently pull straight out on the ribbon to disconnect it from the logic board.
By hand, gently unfold the function button board and lift it off the frame.
Congratulations! The function button board can now be replaced.
取消:我没有完成这个指南。
与4其他贡献者
于2011年01月05日注册
235 信誉积分
创作了2篇指南
徽章: 5
+ 2更多徽章
CPSU-REGAN-W11S3G32
3 名成员
创作了8篇指南
选择尺寸并复制下面的代码嵌入本指南,为你网站/论坛的一个小插件。
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 1,850
