跳转到主内容
Canon PowerShot SD1100 IS Function Buttons Replacement
你所需要的
  1. Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: 步骤 1 中的图像 1,2 Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: 步骤 1 中的图像 2,2
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 2 中的图像 1,3 Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 2 中的图像 2,3 Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 2 中的图像 3,3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 3 中的图像 1,3 Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 3 中的图像 2,3 Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 3 中的图像 3,3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 4 中的图像 1,1
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Function Buttons Replacement, Top Button Assembly: 步骤 5 中的图像 1,1
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 6 中的图像 1,1
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 8 中的图像 1,1
    • The shutter button assembly should now be removed.
  9. Canon PowerShot SD1100 IS Function Buttons Replacement, Function Buttons: 步骤 9 中的图像 1,1
    • With the spudger, flip up the black tab on the main ribbon.
  10. Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 10 中的图像 1,2 Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 10 中的图像 2,2
    • Gently pull straight out on the ribbon to disconnect it from the logic board.
  11. Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 11 中的图像 1,1
    • By hand, gently unfold the function button board and lift it off the frame.
  12. Canon PowerShot SD1100 IS Function Buttons Replacement: 步骤 12 中的图像 1,1
    • Congratulations! The function button board can now be replaced.
结论
Wyatt Chan
于01/05/11注册
235 声望
创作了2篇指南
团队
Cal Poly, Team 3-32, Regan Winter 2011 Cal Poly, Team 3-32, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G32
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,094
