跳转到主内容
Canon PowerShot SD1000 Shutter Button Replacement
你所需要的
  1. Canon PowerShot SD1000 Shutter Button Replacement, Back Panel: 步骤 1 中的图像 1,2 Canon PowerShot SD1000 Shutter Button Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Shutter Button Replacement: 步骤 2 中的图像 1,1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Shutter Button Replacement: 步骤 3 中的图像 1,1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Shutter Button Replacement: 步骤 4 中的图像 1,1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Shutter Button Replacement: 步骤 5 中的图像 1,1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Shutter Button Replacement, Front Case: 步骤 6 中的图像 1,1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Shutter Button Replacement: 步骤 7 中的图像 1,1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Shutter Button Replacement, Shutter Button: 步骤 8 中的图像 1,2 Canon PowerShot SD1000 Shutter Button Replacement, Shutter Button: 步骤 8 中的图像 2,2
    • Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
结论
Phillip Phung
于01/19/12注册
666 声望
创作了9篇指南
团队
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G18
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 1,351
