跳转到主内容
修复你的物品
维修的权力
配件 & 工具
配件
没有特定配件。
  1. Remove the two screws from the side panel closest to the camera lens. Note: These screws are 2.9 mm long.
    • Remove the two screws from the side panel closest to the camera lens.
    • Note: These screws are 2.9 mm long.
  2. Remove the two screws from the camera bottom panel.
    • Remove the two screws from the camera bottom panel.
  3. Remove the 2 screws from the side panel farthest from the lens.
    • Remove the 2 screws from the side panel farthest from the lens.
  4. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  5. Pull the back panel away from the camera body, starting at the end with the function buttons.
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  6. Remove the small cover panel and attached wrist strap mount.
    • Remove the small cover panel and attached wrist strap mount.
  7. Remove the front cover by gently pulling it away from the camera body.
    • Remove the front cover by gently pulling it away from the camera body.
  8. Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
结论
Phillip Phung
于2012年01月19日注册
486 信誉积分
创作了9篇指南
团队
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G18
4 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,045
