跳转到主内容
Canon PowerShot SD1000 Flash Unit Replacement
你所需要的
  1. Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: 步骤 1 中的图像 1,2 Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 2 中的图像 1,1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 3 中的图像 1,1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 4 中的图像 1,1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 5 中的图像 1,1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Flash Unit Replacement, Front Case: 步骤 6 中的图像 1,1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 7 中的图像 1,1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Flash Unit Replacement, LCD Screen: 步骤 8 中的图像 1,1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 9 中的图像 1,2 Canon PowerShot SD1000 Flash Unit Replacement: 步骤 9 中的图像 2,2
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 10 中的图像 1,1
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 11 中的图像 1,2 Canon PowerShot SD1000 Flash Unit Replacement: 步骤 11 中的图像 2,2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 12 中的图像 1,3 Canon PowerShot SD1000 Flash Unit Replacement: 步骤 12 中的图像 2,3 Canon PowerShot SD1000 Flash Unit Replacement: 步骤 12 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
  13. Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: 步骤 13 中的图像 1,2 Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: 步骤 13 中的图像 2,2
    • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
  14. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 14 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
  15. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 15 中的图像 1,1
    • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
  16. Canon PowerShot SD1000 Flash Unit Replacement: 步骤 16 中的图像 1,2 Canon PowerShot SD1000 Flash Unit Replacement: 步骤 16 中的图像 2,2
    • Pull the flash assembly forward out of the camera to remove it.
    • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
结论
另外一个人完成了本指南。
Phillip Phung
于01/19/12注册
651 声望
创作了9篇指南
团队
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G18
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 33
总计 3,175
