跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide is for replacing the speaker on your Canon PowerShot S80. If you have already checked your volume settings and the speaker still does not give audio cues when the camera is in use, this guide will help you replace the faulty speaker.
配件
没有特定配件。
  1. Remove the knot on the wrist lanyard. Remove the battery and memory card.
    • Remove the knot on the wrist lanyard.
    • Remove the battery and memory card.
  2. Remove all screws from sides of outer casing. Begin removing the screws on the bottom of the outer casing.
    • Remove all screws from sides of outer casing.
    • Begin removing the screws on the bottom of the outer casing.
    • Remove the rest of the screws from the outer casing.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Gently pull the front cover off the camera. Gently pull the front cover off the camera. Gently pull the front cover off the camera.
    • Gently pull the front cover off the camera.
  5. Open the "A/V Out Digital" cover slide, and remove the screw inside. Gently pull off the back casing. Remove the black "L" shaped piece of metal.
    • Open the "A/V Out Digital" cover slide, and remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  6. Remove the screw and unplug the wire lead.
    • Remove the screw and unplug the wire lead.
    • Gently remove the speaker from the camera body.
结论
BrettH
于2009年10月28日注册
219 信誉积分
创作了5篇指南
团队
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012 的会员
CPSU-MANESS-SU12S19G5
1 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 2
总计 1,869
