跳转到主内容
Canon PowerShot S80 Motherboard Replacement
你所需要的
  1. Canon PowerShot S80 Motherboard Replacement, Outer Casing: 步骤 1 中的图像 1,2 Canon PowerShot S80 Motherboard Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Motherboard Replacement: 步骤 2 中的图像 1,2 Canon PowerShot S80 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Motherboard Replacement: 步骤 3 中的图像 1,3 Canon PowerShot S80 Motherboard Replacement: 步骤 3 中的图像 2,3 Canon PowerShot S80 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Motherboard Replacement: 步骤 4 中的图像 1,3 Canon PowerShot S80 Motherboard Replacement: 步骤 4 中的图像 2,3 Canon PowerShot S80 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Motherboard Replacement, LCD Screen: 步骤 5 中的图像 1,1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Motherboard Replacement: 步骤 6 中的图像 1,2 Canon PowerShot S80 Motherboard Replacement: 步骤 6 中的图像 2,2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Remove the screws holding down the function set button.
  8. Canon PowerShot S80 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Gently pry up the tab with a metal spudger and remove the ribbon cable.
  9. Canon PowerShot S80 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Be mindful of the pins as you lift up and remove the function/set button.
  10. Canon PowerShot S80 Motherboard Replacement: 步骤 10 中的图像 1,3 Canon PowerShot S80 Motherboard Replacement: 步骤 10 中的图像 2,3 Canon PowerShot S80 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Remove the screws from the metal plate.
    • Gently remove the metal plate.
  11. Canon PowerShot S80 Motherboard Replacement: 步骤 11 中的图像 1,2 Canon PowerShot S80 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Lift the tab connecting the ribbon cable and detach.
  12. Canon PowerShot S80 Motherboard Replacement: 步骤 12 中的图像 1,2 Canon PowerShot S80 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Use a spudger to lift up the ribbon cable tab.
    • Detach the ribbon cable.
  13. Canon PowerShot S80 Motherboard Replacement: 步骤 13 中的图像 1,2 Canon PowerShot S80 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Gently remove the entire ribbon cable connection to release the ribbon cable from the camera.
  14. Canon PowerShot S80 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Unscrew the circuit board from the flash unit.
  15. Canon PowerShot S80 Motherboard Replacement: 步骤 15 中的图像 1,3 Canon PowerShot S80 Motherboard Replacement: 步骤 15 中的图像 2,3 Canon PowerShot S80 Motherboard Replacement: 步骤 15 中的图像 3,3
    • Pry up the ribbon cable connection and remove it from the camera.
    • Lift the ribbon cable tab and completely detach the cable from the camera.
  16. Canon PowerShot S80 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Pry up the connection, being mindful of the light adhesive.
  17. Canon PowerShot S80 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Remove the last screw holding the motherboard to the main body.
  18. Canon PowerShot S80 Motherboard Replacement: 步骤 18 中的图像 1,2 Canon PowerShot S80 Motherboard Replacement: 步骤 18 中的图像 2,2
    • Use a spudger to gently lift the motherboard from the camera.
结论
2等其他人完成本指南。
BrettH
于10/28/09注册
219 声望
创作了5篇指南
团队
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012 的会员
CPSU-MANESS-SU12S19G5
1 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 4,448
