跳转到主内容
Canon PowerShot S80 LCD Screen Replacement
你所需要的
  1. Canon PowerShot S80 LCD Screen Replacement, Outer Casing: 步骤 1 中的图像 1,2 Canon PowerShot S80 LCD Screen Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 LCD Screen Replacement: 步骤 2 中的图像 1,2 Canon PowerShot S80 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 LCD Screen Replacement: 步骤 3 中的图像 1,3 Canon PowerShot S80 LCD Screen Replacement: 步骤 3 中的图像 2,3 Canon PowerShot S80 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 LCD Screen Replacement: 步骤 4 中的图像 1,3 Canon PowerShot S80 LCD Screen Replacement: 步骤 4 中的图像 2,3 Canon PowerShot S80 LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 1,1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 LCD Screen Replacement: 步骤 6 中的图像 1,2 Canon PowerShot S80 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
结论
3等其他人完成本指南。
BrettH
于10/28/09注册
219 声望
创作了5篇指南
团队
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012 的会员
CPSU-MANESS-SU12S19G5
1 名成员
创作了5篇指南
2指南评论
I presume the narrow ribbon cable supplies power to the backlight behind the screen? I replaced the combined screen and backlight assembly. I now have an image but it is extremely dark, barely visible. Perhaps the backlight didn't come on?
The contacts on both the wide ribbon and the narrow ribbon were corroded, probably the source of the problem.
Any suggestions?
Clive Williams - 回复
I found very easy to follow the instructions provided. I just commenta that the last step should be completed by the separation between the screen and the support plate, which is not shown. However if one reaches that point (having the replacement part at hands) it has easy to find the next step of the “surgery”.
Goodinstruction. Thanks to this I brought to new life my Canon Powrr shot S80
attilio.brighenti - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 7,552
