跳转到主内容
Canon PowerShot S80 Flash Replacement
你所需要的
  1. Canon PowerShot S80 Flash Replacement, Outer Casing: 步骤 1 中的图像 1,2 Canon PowerShot S80 Flash Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Flash Replacement: 步骤 2 中的图像 1,2 Canon PowerShot S80 Flash Replacement: 步骤 2 中的图像 2,2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Flash Replacement: 步骤 3 中的图像 1,3 Canon PowerShot S80 Flash Replacement: 步骤 3 中的图像 2,3 Canon PowerShot S80 Flash Replacement: 步骤 3 中的图像 3,3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Flash Replacement: 步骤 4 中的图像 1,3 Canon PowerShot S80 Flash Replacement: 步骤 4 中的图像 2,3 Canon PowerShot S80 Flash Replacement: 步骤 4 中的图像 3,3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Flash Replacement, LCD Screen: 步骤 5 中的图像 1,1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Flash Replacement: 步骤 6 中的图像 1,2 Canon PowerShot S80 Flash Replacement: 步骤 6 中的图像 2,2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Flash Replacement, Flash: 步骤 7 中的图像 1,1
    • Remove the L-shaped corner trim containing the picture button.
    • Carefully unplug the connection cable that is attached.
  8. Canon PowerShot S80 Flash Replacement: 步骤 8 中的图像 1,2 Canon PowerShot S80 Flash Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Pull the selector wheel from the top corner of the camera.
    • Carefully remove the ribbon cable connection with a set of tweezers.
  9. Canon PowerShot S80 Flash Replacement: 步骤 9 中的图像 1,1
    • With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
  10. Canon PowerShot S80 Flash Replacement: 步骤 10 中的图像 1,1
    • With a Phillips #00 Screwdriver, unscrew the flash board.
  11. Canon PowerShot S80 Flash Replacement: 步骤 11 中的图像 1,1
    • Remove the cable connection. With a metal spudger, gently pry up.
    • Remove the ribon cable. With a metal spudger, gently lift up the black tab.
  12. Canon PowerShot S80 Flash Replacement: 步骤 12 中的图像 1,1
    • Lift the flash bulb unit upwards from the camera.
  13. Canon PowerShot S80 Flash Replacement: 步骤 13 中的图像 1,2 Canon PowerShot S80 Flash Replacement: 步骤 13 中的图像 2,2
    • Lift the entire three-part flash assembly from the camera.
结论
BrettH
于10/28/09注册
219 声望
创作了5篇指南
团队
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012 的会员
CPSU-MANESS-SU12S19G5
1 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 6
总计 3,701
