跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot S500 LCD Replacement
你所需要的
  1. Canon PowerShot S500 LCD Replacement, Front and Rear Casing : 步骤 1 中的图像 1,2 Canon PowerShot S500 LCD Replacement, Front and Rear Casing : 步骤 1 中的图像 2,2
    • Unscrew five Phillips screws using a #0 Phillips screwdriver.
    • One screw is on upper right corner of the back panel.
    • The other four screws are on the bottom of the camera.
    询问修复机器人
    添加评论
  2. Canon PowerShot S500 LCD Replacement: 步骤 2 中的图像 1,1
    • Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Remove the memory card from the slot.
    询问修复机器人
    添加评论
  3. Canon PowerShot S500 LCD Replacement: 步骤 3 中的图像 1,1
    • Remove the rear cover from the rest of the camera.
    • This may require gentle rocking of the case to free it.
    询问修复机器人
    添加评论
  4. Canon PowerShot S500 LCD Replacement: 步骤 4 中的图像 1,2 Canon PowerShot S500 LCD Replacement: 步骤 4 中的图像 2,2
    • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
    询问修复机器人
    添加评论
  5. Canon PowerShot S500 LCD Replacement: 步骤 5 中的图像 1,1
    • Free the front cover from the rest of the camera.
    • The cover may require gentle rocking to remove.
    询问修复机器人
    添加评论
  6. Canon PowerShot S500 LCD Replacement, LCD: 步骤 6 中的图像 1,1
    • Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
    询问修复机器人
    添加评论
  7. Canon PowerShot S500 LCD Replacement: 步骤 7 中的图像 1,1
    • Gently separate the top of LCD from the rest of the camera using your thumb.
    • Be careful not pull the LCD too far because of the ribbon cable connection.
    • Place the Spudger in the hole of the electrical ribbon.
    • Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
    • The LCD will still be connected to the rest of the camera
    询问修复机器人
    添加评论
  8. Canon PowerShot S500 LCD Replacement: 步骤 8 中的图像 1,2 Canon PowerShot S500 LCD Replacement: 步骤 8 中的图像 2,2
    • Unscrew single Phillips screw with a #0 Phillips screwdriver.
    • Free the bottom panel and attached ribbon from the rest of the camera.
    • Be careful not to damage the ribbon.
    询问修复机器人
    添加评论
  9. Canon PowerShot S500 LCD Replacement: 步骤 9 中的图像 1,1
    • Turn over the camera.
    • Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
    • The plastic will still be connected on the left side.
    询问修复机器人
    添加评论
  10. Canon PowerShot S500 LCD Replacement: 步骤 10 中的图像 1,1
    • Place the Spudger between the orange ribbon and the black ribbon gate.
    • Lift the ribbon gate using the Spudger.
    询问修复机器人
    添加评论
  11. Canon PowerShot S500 LCD Replacement: 步骤 11 中的图像 1,1
    • Place the Spudger in the corner of the ribbon above the hole.
    • Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
    询问修复机器人
    添加评论
  12. Canon PowerShot S500 LCD Replacement: 步骤 12 中的图像 1,1
    • Free this ribbon and the bottom panel from the rest of the camera.
    询问修复机器人
    添加评论
  13. Canon PowerShot S500 LCD Replacement: 步骤 13 中的图像 1,1
    • Turn the camera over so you can see the LCD.
    • Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
    询问修复机器人
    添加评论
  14. Canon PowerShot S500 LCD Replacement: 步骤 14 中的图像 1,1
    • Lift the blue ribbon gate using the Spudger.
    询问修复机器人
    添加评论
  15. Canon PowerShot S500 LCD Replacement: 步骤 15 中的图像 1,1
    • Insert the Spudger into the hole of the ribbon.
    • Move the Spudger away from the gate to fully remove ribbon.
    询问修复机器人
    添加评论
  16. Canon PowerShot S500 LCD Replacement: 步骤 16 中的图像 1,1
    • Lift the LCD away from the rest of the camera.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Nathan Balcom
于01/21/10注册
102 声望
创作了8篇指南
团队
Cal Poly, Team 16-28, Maness Winter 2010 Cal Poly, Team 16-28, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G28
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 39
总计 3,656
