当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Unscrew five Phillips screws using a #0 Phillips screwdriver.
One screw is on upper right corner of the back panel.
The other four screws are on the bottom of the camera.
Open the memory card cover by moving the slide switch toward the top end of of the camera.
Remove the memory card from the slot.
Remove the rear cover from the rest of the camera.
This may require gentle rocking of the case to free it.
Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
Free the front cover from the rest of the camera.
The cover may require gentle rocking to remove.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与6其他贡献者
于01/21/10注册
81 声望
创作了8篇指南
徽章: 9
+ 6更多徽章
CPSU-MANESS-W10S16G28
4 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 1,614
