当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the 3mm screw on the top left.
NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
Now remove the 5.3mm screw on the bottom.
Lift open the rubber flap covering the A/V Out port.
Remove the 3.4mm screw in the center.
During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
Remove the 2.6mm screw on the bottom of the camera located directly under the LCD screen.
This screw should be holding two pieces of orange film down.
When replacing this screw, make sure that the orange film is secure below it before screwing it in.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
