跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot S410 LCD Screen Replacement
你所需要的
  1. Canon PowerShot S410 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 Canon PowerShot S410 LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. Canon PowerShot S410 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Pull the orange lever and the battery will spring out slightly.
  3. Canon PowerShot S410 LCD Screen Replacement: 步骤 3 中的图像 1,2 Canon PowerShot S410 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
  4. Canon PowerShot S410 LCD Screen Replacement, Back Cover: 步骤 4 中的图像 1,1
    • Start by laying the camera flat with the LCD screen facing up.
    • Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
  5. Canon PowerShot S410 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Position the camera with the bottom facing up.
    • Twist the screwdriver counter-clockwise to remove the 4.8mm screw.
    • Repeat to remove the two 2.3mm screws.
  6. Canon PowerShot S410 LCD Screen Replacement: 步骤 6 中的图像 1,2 Canon PowerShot S410 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Position the camera so that the rubber "AV Out Digital" tab is facing upward.
    • Slide the rubber tab to reveal the bottom screw.
    • Using the screwdriver, remove the two 3.7mm screws.
  7. Canon PowerShot S410 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Turn the camera with the back side facing you.
    • Grip the edges of the back plate, and carefully slide it off.
    • If there is any resistance in movement, double check there are no screws left in the chassis.
  8. Canon PowerShot S410 LCD Screen Replacement, Front Cover: 步骤 8 中的图像 1,2 Canon PowerShot S410 LCD Screen Replacement, Front Cover: 步骤 8 中的图像 2,2
    • Orient the camera as in the picture.
    • Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
    • Remove the two 3.8mm screws near the strap bracket.
    • Remove the small panel covering the mounting bracket.
    • Remove the door covering the memory card.
  9. Canon PowerShot S410 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Rotate the camera so that the bottom side is facing you.
    • Remove the 3.8mm screw below the mounting bracket using the Phillips screwdriver.
  10. Canon PowerShot S410 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Rotate the camera so that the front is facing you.
    • Grasp the sides of the front cover and carefully pull the front panel off of the camera.
  11. Canon PowerShot S410 LCD Screen Replacement, LCD Screen: 步骤 11 中的图像 1,2 Canon PowerShot S410 LCD Screen Replacement, LCD Screen: 步骤 11 中的图像 2,2
    • Position the camera so that the motherboard is facing you.
    • A fingernail or spudger can be used to remove the plastic flap covering the motherboard.
  12. Canon PowerShot S410 LCD Screen Replacement: 步骤 12 中的图像 1,2 Canon PowerShot S410 LCD Screen Replacement: 步骤 12 中的图像 2,2
    • Turn the camera so that the bottom side is facing you.
    • Remove the 2.1mm screw using the Phillips #0 screwdriver
    • Grab the sides of the bottom panel and lift to expose the ribbon cable.
  13. Canon PowerShot S410 LCD Screen Replacement: 步骤 13 中的图像 1,2 Canon PowerShot S410 LCD Screen Replacement: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    • Turn the camera so that the motherboard is facing you.
    • Using your fingernail, open the black clip holding the ribbon cable.
    • Gently pull out the ribbon cable in the direction of the cable using your fingers or tweezers.
  14. Canon PowerShot S410 LCD Screen Replacement: 步骤 14 中的图像 1,1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the two 2.1mm screws on the aluminum tabs of the LCD screen using a screwdriver.
  15. Canon PowerShot S410 LCD Screen Replacement: 步骤 15 中的图像 1,2 Canon PowerShot S410 LCD Screen Replacement: 步骤 15 中的图像 2,2
    • Using a pair of tweezers, carefully pull the top ribbon cable out of the slot.
    • Grasp the sides of the LCD screen and lift off of the camera.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
kubayubay
于01/23/11注册
103 声望
撰写一个指南
团队
Cal Poly, Team 11-27, Maness Winter 2011 Cal Poly, Team 11-27, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G27
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 80
总计 4,049
