简介
This guide shows you how to remove and replace the front cover of your Canon PowerShot S410 camera. You may need to replace the front cover if you've damaged it or if you need to access the internal components of the camera for additional repairs.
你所需要的
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
Remove the two 3.8mm screws near the strap bracket.
Remove the small panel covering the mounting bracket.
Remove the door covering the memory card.
