当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Turn the camera with the bottom side facing up.
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Grasp the battery and fully pull it out of its slot.
When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
Start by laying the camera flat with the LCD screen facing up.
Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
Position the camera with the bottom facing up.
Twist the screwdriver counter-clockwise to remove the 4.8mm screw.
Repeat to remove the two 2.3mm screws.
Position the camera so that the rubber "AV Out Digital" tab is facing upward.
Slide the rubber tab to reveal the bottom screw.
Using the screwdriver, remove the two 3.7mm screws.
Turn the camera with the back side facing you.
Grip the edges of the back plate, and carefully slide it off.
If there is any resistance in movement, double check there are no screws left in the chassis.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
