跳转到主内容
Canon PowerShot S400 Shutter Button Assembly Replacement
你所需要的
  1. Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: 步骤 1 中的图像 1,2 Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: 步骤 1 中的图像 2,2
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Canon PowerShot S400 Shutter Button Assembly Replacement: 步骤 2 中的图像 1,3 Canon PowerShot S400 Shutter Button Assembly Replacement: 步骤 2 中的图像 2,3 Canon PowerShot S400 Shutter Button Assembly Replacement: 步骤 2 中的图像 3,3
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. Canon PowerShot S400 Shutter Button Assembly Replacement: 步骤 3 中的图像 1,3 Canon PowerShot S400 Shutter Button Assembly Replacement: 步骤 3 中的图像 2,3 Canon PowerShot S400 Shutter Button Assembly Replacement: 步骤 3 中的图像 3,3
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  4. Canon PowerShot S400 Shutter Button Assembly Replacement: 步骤 4 中的图像 1,1
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
结论
Ross Bryan
于01/21/11注册
374 声望
创作了3篇指南
团队
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G19
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 2,766
