跳转到主内容
Canon PowerShot S400 SD Card Slot Replacement
你所需要的
  1. Canon PowerShot S400 SD Card Slot Replacement, SD Card Slot: 步骤 1 中的图像 1,2 Canon PowerShot S400 SD Card Slot Replacement, SD Card Slot: 步骤 1 中的图像 2,2
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four 4.75mm screws located on the bottom of the camera.
  2. Canon PowerShot S400 SD Card Slot Replacement: 步骤 2 中的图像 1,1
    • Remove the two 4.75mm screws located on the right side of the camera.(the side with the USB adaption plug)
  3. Canon PowerShot S400 SD Card Slot Replacement: 步骤 3 中的图像 1,3 Canon PowerShot S400 SD Card Slot Replacement: 步骤 3 中的图像 2,3 Canon PowerShot S400 SD Card Slot Replacement: 步骤 3 中的图像 3,3
    • Remove the four 4.75mm screws on the left side of the camera.
    • This will release two small metal plates. Remove these plate.
  4. Canon PowerShot S400 SD Card Slot Replacement: 步骤 4 中的图像 1,1
    • Only remove the back case.
    • The memory card is held in the metal case located to the right of the LCD screen.
    • Remove the stuck memory card.
    • If you still cannot remove the stuck memory card, proceed with further instructions. If you could remove the memory card then you are done
  5. Canon PowerShot S400 SD Card Slot Replacement: 步骤 5 中的图像 1,2 Canon PowerShot S400 SD Card Slot Replacement: 步骤 5 中的图像 2,2
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Separate the front casing from the camera
  6. Canon PowerShot S400 SD Card Slot Replacement: 步骤 6 中的图像 1,2 Canon PowerShot S400 SD Card Slot Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • If the small plastic piece described in the previous step did not fall out, remove it now. The piece is located in a small gap above the lens and to the left of the flash.
    • Removing this piece may require the use of tweezers.
  7. Canon PowerShot S400 SD Card Slot Replacement: 步骤 7 中的图像 1,2 Canon PowerShot S400 SD Card Slot Replacement: 步骤 7 中的图像 2,2
    • Locate and remove the three 3.45mm screws on the backside of the camera securing the CF card slot.
    • Do not remove ribbon cable. It is not necessary to remove
    • Without removing the ribbon cable, gently remove the memory card.
结论
Adam Grijalva
于01/20/11注册
202 声望
创作了2篇指南
团队
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G19
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 4,073
