跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot S400 Battery Replacement
你所需要的
    1. Canon PowerShot S400 Battery Replacement, LCD Screen: 步骤 1 中的图像 1,2 Canon PowerShot S400 Battery Replacement, LCD Screen: 步骤 1 中的图像 2,2
      • Unless stated otherwise, use a Phillips #00 screwdriver to remove all screws.
      • On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
      • Remove the four 4.75 mm screws that sit at the bottom of the camera.
      询问修复机器人
      添加评论
    2. Canon PowerShot S400 Battery Replacement: 步骤 2 中的图像 1,1
      • On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
      询问修复机器人
      添加评论
    3. Canon PowerShot S400 Battery Replacement: 步骤 3 中的图像 1,3 Canon PowerShot S400 Battery Replacement: 步骤 3 中的图像 2,3 Canon PowerShot S400 Battery Replacement: 步骤 3 中的图像 3,3
      • On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
      • Remove the two small metal plates, which the four screws hold in place.
      添加评论
    4. Canon PowerShot S400 Battery Replacement: 步骤 4 中的图像 1,2 Canon PowerShot S400 Battery Replacement: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      • When removing the casing, do not drop the small black plastic piece. This piece sits in a small gap above the lens, to the left of the flash, and underneath the camera case.
      • Remove the small black plastic piece and set it aside. If necessary, use tweezers to remove the small black plastic piece.
      • Detach the front case and back case.
      添加评论
    5. Canon PowerShot S400 Battery Replacement: 步骤 5 中的图像 1,1
      • Do not remove the metal plate this step refers to. Removal at this step may damage the ribbon cable. Wait until the next step to remove the plate.
      • Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
      • Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
      • In the image, we have already removed some of the screws.
      询问修复机器人
      添加评论
    6. Canon PowerShot S400 Battery Replacement: 步骤 6 中的图像 1,3 Canon PowerShot S400 Battery Replacement: 步骤 6 中的图像 2,3 Canon PowerShot S400 Battery Replacement: 步骤 6 中的图像 3,3
      • A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
      • Gently release the black latch.
      • Remove the ribbon cable and metal plate assembly.
      询问修复机器人
      添加评论
    7. Canon PowerShot S400 Battery Replacement: 步骤 7 中的图像 1,2 Canon PowerShot S400 Battery Replacement: 步骤 7 中的图像 2,2
      • On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
      • Remove the second 3.5 mm screw that sits directly above the LCD screen.
      • Gently detach the ribbon cable.
      询问修复机器人
      添加评论
    8. Canon PowerShot S400 Battery Replacement: 步骤 8 中的图像 1,1
      • Locate the ribbon cable on the main circuit board, which sits below the lens.
      • Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
      询问修复机器人
      添加评论
    9. Canon PowerShot S400 Battery Replacement: 步骤 9 中的图像 1,2 Canon PowerShot S400 Battery Replacement: 步骤 9 中的图像 2,2
      • Remove the LCD screen and set it aside.
      询问修复机器人
      添加评论
    1. Canon PowerShot S400 Battery Replacement, Battery: 步骤 10 中的图像 1,1
      • Locate the ribbon cable connection to the left of the lens on the main circuit board.
      • Gently flip open the black latch on the connector and detach the ribbon cable.
      询问修复机器人
      添加评论
    2. Canon PowerShot S400 Battery Replacement: 步骤 11 中的图像 1,1
      • Locate the three ribbon cables on the main circuit board. Gently flip open these black latches.
      • Gently disconnect the ribbon cables.
      询问修复机器人
      添加评论
    3. Canon PowerShot S400 Battery Replacement: 步骤 12 中的图像 1,2 Canon PowerShot S400 Battery Replacement: 步骤 12 中的图像 2,2
      • Locate the white and green connectors underneath the flash.
      • Gently disconnect these connectors.
      询问修复机器人
      添加评论
    4. Canon PowerShot S400 Battery Replacement: 步骤 13 中的图像 1,1
      • Using a spudger, carefully pry the shutter button assembly from the camera.
      询问修复机器人
      添加评论
    5. Canon PowerShot S400 Battery Replacement: 步骤 14 中的图像 1,1
      • Remove the four screws securing the main circuit board to the rest of the camera. (In the image, some of the screws have already been removed)
      • Do not remove the main circuit board yet.
      询问修复机器人
      添加评论
    6. Canon PowerShot S400 Battery Replacement: 步骤 15 中的图像 1,3 Canon PowerShot S400 Battery Replacement: 步骤 15 中的图像 2,3 Canon PowerShot S400 Battery Replacement: 步骤 15 中的图像 3,3
      • Do not completely lift the circuit board off the camera. The circuit board is attached to the top of the camera by a soldered ribbon cable. Lifting the main circuit board off the camera will break these soldering points.
      • Gently lift the bottom of the main circuit board, the side without the soldered attachment points, like a hinge.
      • Locate the white ribbon cable attached to the underside of the main circuit board.
      • Gently remove the white ribbon cable from the connector.
      询问修复机器人
      添加评论
    7. Canon PowerShot S400 Battery Replacement: 步骤 16 中的图像 1,2 Canon PowerShot S400 Battery Replacement: 步骤 16 中的图像 2,2
      • Locate and remove the three 3.45mm screws on the backside of the camera that secure the CF card slot.
      • Make note of the orientation of the ribbon cable connected to the CF card slot. You will need this for re-assembly.
      • Gently remove the CF card slot.
      询问修复机器人
      添加评论
    8. Canon PowerShot S400 Battery Replacement: 步骤 17 中的图像 1,1
      • Orient the camera so you are looking at the top.
      • Locate the white connector that attaches the flex circuit to the capacitor.
      • You may have to pull the connector out of a small space behind the flash bulb in order to access it.
      • Disconnect the connector.
      询问修复机器人
      添加评论
    9. Canon PowerShot S400 Battery Replacement: 步骤 18 中的图像 1,1
      • Adhesive tape attaches the flex circuit to the top of the camera. Gently un-stick the flex circuit from the tape, but do not completely remove the flex circuit.
      询问修复机器人
      添加评论
    10. Canon PowerShot S400 Battery Replacement: 步骤 19 中的图像 1,2 Canon PowerShot S400 Battery Replacement: 步骤 19 中的图像 2,2
      • Remove the two 3.45mm screws located on the backside of the camera.
      • Separate the battery compartment and the lens-flash assembly.
      询问修复机器人
      添加评论
    11. Canon PowerShot S400 Battery Replacement: 步骤 20 中的图像 1,1
      • Set the lens-flash assembly aside.
      • The next step requires the use of a soldering iron. Do not perform this step if you do not have experience soldering, you could permanently damage the mother board
      • De-solder the two soldered ribbon cables attached to the motherboard.
      • Separate the motherboard and battery case.
      询问修复机器人
      添加评论
    12. Canon PowerShot S400 Battery Replacement: 步骤 21 中的图像 1,1
      • Replace battery casing
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Adam Grijalva
于01/20/11注册
202 声望
创作了2篇指南
团队
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G19
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 44
总计 3,820
