跳转到主内容
Canon PowerShot S230 Display Screen Replacement
你所需要的
  1. Canon PowerShot S230 Display Screen Replacement, Display Screen: 步骤 1 中的图像 1,1
    • Using a Phillips #0 head screwdriver, remove the screws on the outside casing of the camera.
  2. Canon PowerShot S230 Display Screen Replacement: 步骤 2 中的图像 1,3 Canon PowerShot S230 Display Screen Replacement: 步骤 2 中的图像 2,3 Canon PowerShot S230 Display Screen Replacement: 步骤 2 中的图像 3,3
    • Use a pry tool to open the outer casing of the camera and access the internal components.
  3. Canon PowerShot S230 Display Screen Replacement: 步骤 3 中的图像 1,2 Canon PowerShot S230 Display Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the metal shield and screws from the bottom interior of the camera.
  4. Canon PowerShot S230 Display Screen Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips head screwdriver to remove the screws securing the screen.
  5. Canon PowerShot S230 Display Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the screws on the copper facing from the front part of the camera. Beneath is a connection to the screen. Wiggle this connection to pull it out; it may take some force to do so.
结论
Will Appleton
于05/31/16注册
101 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 16
总计 250
