跳转到主内容
Canon PowerShot S230 Display Screen Replacement
你所需要的
  1. Canon PowerShot S230 Display Screen Replacement, Display Screen: 步骤 1 中的图像 1,1
    • Unscrewing the small screws to take off the backing, screws are on the side and there are 4
  2. Canon PowerShot S230 Display Screen Replacement: 步骤 2 中的图像 1,3 Canon PowerShot S230 Display Screen Replacement: 步骤 2 中的图像 2,3 Canon PowerShot S230 Display Screen Replacement: 步骤 2 中的图像 3,3
    • Pry open the backing
    • Look for all screws before moving on
  3. Canon PowerShot S230 Display Screen Replacement: 步骤 3 中的图像 1,1
    • Remove metal shield from camera
    • It's fine if you just use your hands
  4. Canon PowerShot S230 Display Screen Replacement: 步骤 4 中的图像 1,1
    • Pry off the the front casing
    • REMOVE ALL SCREWS BEFORE MOVING ON
  5. Canon PowerShot S230 Display Screen Replacement: 步骤 5 中的图像 1,2 Canon PowerShot S230 Display Screen Replacement: 步骤 5 中的图像 2,2
    • Remove screws and metal shield at the bottom of the camera
  6. Canon PowerShot S230 Display Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the screen, also remove any screws that may get in the way, if the screen pops out it’s okay, it’s suppose to do that. Remove the screw at the bottom
  7. Canon PowerShot S230 Display Screen Replacement: 步骤 7 中的图像 1,3 Canon PowerShot S230 Display Screen Replacement: 步骤 7 中的图像 2,3 Canon PowerShot S230 Display Screen Replacement: 步骤 7 中的图像 3,3
    • Remove the highlighted screws to remove the copper facing
    • Now that the screen is replaced, all you need to do is go through the steps in reverse!
结论
Angie
于05/31/16注册
101 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 137
