跳转到主内容
Canon PowerShot G9 SD-Card Slot Write Lock.
你所需要的
  1. Canon PowerShot G9 SD-Card Slot Write Lock., Open rear cover of camera.: 步骤 1 中的图像 1,2 Canon PowerShot G9 SD-Card Slot Write Lock., Open rear cover of camera.: 步骤 1 中的图像 2,2
    • Be very careful not to touch any charged flash capacitor
    • Remove screws as marked. 2 for strap holder, 5 for back cover
    • Remove Back cover and strap holder
  2. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Buttons.: 步骤 2 中的图像 1,2 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Buttons.: 步骤 2 中的图像 2,2
    • Remove the two screws circled green.
    • Remove the buttons.
  3. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: 步骤 3 中的图像 1,3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: 步骤 3 中的图像 2,3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: 步骤 3 中的图像 3,3
    • Disconnect ribbon cable by lifting up flap.
    • Disconnect other cable (another flap)
    • Remove jog dial unit
  4. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Finder dial.: 步骤 4 中的图像 1,2 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Finder dial.: 步骤 4 中的图像 2,2
    • Remove the one screw circled green.
    • Remove the finder dial
  5. Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: 步骤 5 中的图像 1,3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: 步骤 5 中的图像 2,3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: 步骤 5 中的图像 3,3
    • Remove screw and lift LCD upwards very carefully. Do not put any strain on cables.
    • Carefully remove flex cables. The left has a flap that needs to be opened (up), the right just needs to be pulled out. Be careful when re-inserting the right one, you can easily damage the fragile cable.
    • Remove the LCD
  6. Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: 步骤 6 中的图像 1,3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: 步骤 6 中的图像 2,3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: 步骤 6 中的图像 3,3
    • Remove screws.
    • Disconnect connectors for Lens assembly
    • Carefully disconnect the tiny cable
    • Next step is removing the PCB. I made the mistake not to take care about the battery compartment switch. If you are not careful, the black lever will break off. Not a problem though, because then the camera will work also with opened battery compartmen
    • Remove main PCB by slightly bending outward the cover for the jack with fingernail. Now lift the PCB slightly upwards.
    • Look under the PCB, there is a connector that needs to be separated by means of a small screwdriver or spudger.
    • Re-attaching the connector is not easy. I used a small screwdriver to carefully press the connector back in place.
    • This is not the official method to do this. Normally the Top cover and several other parts need to be removed too.
  7. Canon PowerShot G9 SD-Card Slot Write Lock., Check SD-Card Slot.: 步骤 7 中的图像 1,2 Canon PowerShot G9 SD-Card Slot Write Lock., Check SD-Card Slot.: 步骤 7 中的图像 2,2
    • Measure continuity with a multimeter on SD-card slot write protect switch.
    • If it is not working, short the two points with a bodge wire, so write lock is disabled
    • Another possible fault is a broken soldering joint holding the case of the SD-card reader in place.
结论
Repeat the steps in order to reassemble your device.
另外一个人完成了本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Thomas Widmaier
于03/05/13注册
2,039 声望
创作了10篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,536篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 20
总计 1,048
