跳转到主内容
Canon PowerShot G7X Motherboard Replacement
你所需要的
  1. Canon PowerShot G7X Motherboard Replacement, Dial: 步骤 1 中的图像 1,1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the back plate.
  6. Canon PowerShot G7X Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Motherboard Replacement: 步骤 7 中的图像 1,2 Canon PowerShot G7X Motherboard Replacement: 步骤 7 中的图像 2,2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
  8. Canon PowerShot G7X Motherboard Replacement, Flash: 步骤 8 中的图像 1,2 Canon PowerShot G7X Motherboard Replacement, Flash: 步骤 8 中的图像 2,2
    • Remove the three, blue 5 mm Phillips screws from the back plate.
    • Remove seven 2 mm Phillips #000 screws.
  9. Canon PowerShot G7X Motherboard Replacement: 步骤 9 中的图像 1,2 Canon PowerShot G7X Motherboard Replacement: 步骤 9 中的图像 2,2
    • While using the plastic opening tool, gently pry the top plate off the camera.
  10. Canon PowerShot G7X Motherboard Replacement: 步骤 10 中的图像 1,2 Canon PowerShot G7X Motherboard Replacement: 步骤 10 中的图像 2,2
    • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
  11. Canon PowerShot G7X Motherboard Replacement: 步骤 11 中的图像 1,2 Canon PowerShot G7X Motherboard Replacement: 步骤 11 中的图像 2,2
    • Remove the 2 mm Phillips #000 screw underneath the top plate.
    • Remove silver plate.
  12. Canon PowerShot G7X Motherboard Replacement: 步骤 12 中的图像 1,1
    • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
  13. Canon PowerShot G7X Motherboard Replacement: 步骤 13 中的图像 1,2 Canon PowerShot G7X Motherboard Replacement: 步骤 13 中的图像 2,2
    • Using the spudger, gently lift the ribbon cable from underneath the front plate.
    • Remove the front plate.
  14. Canon PowerShot G7X Motherboard Replacement: 步骤 14 中的图像 1,2 Canon PowerShot G7X Motherboard Replacement: 步骤 14 中的图像 2,2
    • Remove flash toggle plate.
    • Remove the 2mm Phillips #000 screws under the flash toggle.
  15. Canon PowerShot G7X Motherboard Replacement: 步骤 15 中的图像 1,2 Canon PowerShot G7X Motherboard Replacement: 步骤 15 中的图像 2,2
    • Flash contains charged capacitor. Shock hazard.
    • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
  16. Canon PowerShot G7X Motherboard Replacement, Lens: 步骤 16 中的图像 1,1
    • Remove the 5 mm Phillips #000 screw from the copper plate.
  17. Canon PowerShot G7X Motherboard Replacement: 步骤 17 中的图像 1,1
    • Using the black nylon spudger, lift the ribbon cable gently until it comes out.
  18. Canon PowerShot G7X Motherboard Replacement: 步骤 18 中的图像 1,1
    • Remove the copper plate to reveal connections to the lens.
  19. Canon PowerShot G7X Motherboard Replacement: 步骤 19 中的图像 1,1
    • Using the black nylon spudger, lift gently on the pin connector until it comes off.
  20. Canon PowerShot G7X Motherboard Replacement: 步骤 20 中的图像 1,2 Canon PowerShot G7X Motherboard Replacement: 步骤 20 中的图像 2,2
    • Using the spudger, gently lift on the ribbon cable until it comes out.
    • Separate the lens from the motherboard.
  21. Canon PowerShot G7X Motherboard Replacement, Motherboard: 步骤 21 中的图像 1,1
    • Remove the 5 mm Phillips #000 silver, anchor screws from the corners of the motherboard marked in the picture.
  22. Canon PowerShot G7X Motherboard Replacement: 步骤 22 中的图像 1,1
    • Remove motherboard.
结论
另外一个人完成了本指南。
Brandon Lacy
于11/06/19注册
113 声望
撰写一个指南
团队
IUPUI, Team S1-G5, Stella Fall 2019 IUPUI, Team S1-G5, Stella Fall 2019 的会员
IUPUI-STELLA-F19S1G5
3 名成员
创作了5篇指南
一条评论
Very Good!
I Think I Want to DIY Rep My DC
sheep free - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 718
